Converting Asteroids to Lunar Lander
dezbaz
Donor 4 years: 2011, 2013-2014, 2016
Ballajura, Western Australia, Australia
Hi Guys
I have bitten the bullet, and started to totally rebuild an Asteroids Cabinet, which had gotten a bit old and shabby.
I figured as I already have a working Asteroids, I will make the 2nd one into a Lunar Lander
Here's some pics
DISASSEMBLY (The fun part)
I am actually up to the conversion of the control panel, so watch this space as I post up the dozens of pics taken over the last few weeks
The thrust controller is almost finished too from scratch
Thanks for looking
Wow, impressive work! Do you have all the parts to make the Lunar Lander complete, or are you going to finish it as you find them?
That is amazing. I can never imagine having enough woodworking skills to practically re-build an entire cabinet! Keep us updated on your progress.
I have almost all parts, I managed to find them over the last few years :D
The only part I don't have is the 5K resistor pot
Still to make the Mission Control Panel, But I have high res pics
Put in some T-Moulding
Put the sides on the base
Started working out what's involved with the control Panel Conversion
I ran some thinners over the panel to make paint removal easier
Amazing what you find LOL
And more cleaning
Taped it up to measure where the holes will be
Not a bad outcome, the 2 smaller switch holes centre top will removed totally.
I do have to fill a few 29mm holes, but I will use the mig to tack on little fillers
more pics
Made a template to scale which will be used to get it all exactly right
Made some little plugs and migged them in tonight
Grinding till 8.30PM :D
Welding in the dark LOL
Not a bad outcome, I cant really weld that good, but good enough
Orbital to feather the paint edges - 30 yrs of paint, tough stuff
The panel is thick enough to weld without warping the panel
The inside shows the round inserts are thinner than the panel
Welded from the front too
Filled in the little square bolt holes too as they are in the wrong spot too
WOW brother thats inpressive. I will get you those other measurments this week:) Ram controls sells the 5k pot.
I have had to improvise a few things on this project
The pics I have will have to be vectorised IE (Thanks to John's Arcade in Sydney for the MCP Pics and many other details, including dimensions of the thruster) :)
Huge thanks to Dan (djw90) for the high res sideart, marquee pics, measurements of the control panel and for going over and above for me :)
Dan's link is here
http://forums.arcade-museum.com/showthread.php?t=107574&highlight=grail+lunar+lander
I was lucky to find a friend in Aust who has a LL Complete control panel.
I think he wants to do the same as you and me one day too :) Convert an asteroids, or buy a LL (Not aware of any LL's here in Australia)
Pre vectorising above, all that's done is darkening and squared up
Still some major effort to vectorise this
Sweet!!! Im back from vacation now. Let me know if you need anything else. Im very excited for your lander. I hope to see you compete for the world record:001_sbiggrin:
