Winslow
I got my Vectorlabs MutliVector adapter board and I'm about to put everything together and install it into my Space Duel cabinet.
I've got a Black Widow board and two working Space Duel boards.
I want to convert one of the SD boards into Gravitar for the Multivector setup. I'm assuming that all I need to do is to burn the appropriate Gravitar ROMs and install them into the SD board. Was there any other modifications that needs to be done?
Thanks for any advice you can provide. I'm going to pull out the Eprom Burner today and see if I have enough 2532's in stock. I suppose I could reuse the 2532s on the working SD board if I need to. I think there is also a 2716 involved?
Thanks Again !
Steve
Thanks Again !
Steve
