Converting a Redemption Machine
Ohio66
Bel Air, Maryland
I just purchased a Gold Zone ticket redemption machine, but I want to convert it to give coins not tickets. Has anyone done this? What would I have to do?
Ohio66
I'm by no mean an authority on this...
In Gold Zone the tokens/coins fall into a hopper for counting. This is triggered by the falling coins which then simply fall straight into a typical coin box below that.
You'd probably need to invest in another hopper system that would have a supply of tokens/coins, but it would need to be able to count them out too.
As you may have already found out, Gold Zone won't "shut up" until the correct amount of tickets have been dispensed. So the trick here is not only driving your "payout" hopper from the game's ticket signal, but sending the info back to the game telling it that the correct amount had been dispensed as well.
Possibly someone with some slot machine know-how might have some insight on this and/or other member may be able to chime in over the next few days too.
Hopper
Should be able to use the pulses that feed the ticket machine and feed it into the hopper pulse count circuit. You would have to see what the hopper wants to see for a pulse count verses what the machine puts out . The width of the pulse also makes a difference. There might be some dip sw setting on the game for different ticket dispensers.
RJ
