Converting a Galaxian or Galaga to Jamma..
misterted
West Long Branch, New Jersey
If I had one of the 2 uprights listed above, what would I need to turn it into a 48 in 1 or 60 in 1 machine?
Would it just be the Jamma adapter for that particular machine and the actual board?
Is it that easy or would I need to do something more technical?
Galaxian's harness is very similar to a Pac/Ms. Pac, all you would need to do is swap (I believe) 2 wires and a Pac-JAMMA adapter would work. Then the only issue you run into is converting the 2-way joystick to a 4-way, and in most cases youll need a switcher to power the PCB.
Galaga is a different breed that I'm not familiar with, but there is a Galaga JAMMA adapter here:
http://www.jammaboards.com/store/jamma-to-galaga-adapter/prod_210.html
I'm sure a little research will help you here. JAMMA Boards also sells the Pac-JAMMA adapter.
