So, i built a mame adapter i can plug into my arcade harness, just so i can play some more classics, cause i dont have the money or space for the real things (sadly.) My cabinet has an 8 way wico microswitched. The one with the square base. Problem is, that sucks for games like pac man and donkey kong. Its almost impossible to not hit diagonals. So i went into the garage, drilled out a plastic spacer and put on a few washers that fit over the shaft. Works great. It hits every direction, and when pushed around the diagonals has a almost perfectly seemless shift to the other directions. Now i can play ms. pac man and pengo!!
