jimbodeanny
- Joined
- Oct 24, 2004
- Messages
- 4,528
- Reaction score
- 874
I've done a fair amount of searching and haven't been able to find a source for those convergence strips/tabs for correcting convergence around the corners/edges of monitors?
My Wells K7191 looks fantastic right now after recapping/rejuving. The only issue is in the lower right corner of the screen, there's (what I'm guessing) is a slight convergence issue. It's only noticeable when there is visible text. For example, while I have T-MEK running, the "free play" should just be white text, but instead is white with some red shifting to the lower right (kind of like a drop shadow.) It's only in this small area of the monitor, so I'm thinking of trying to cure it with some convergence strips, but I can't seem to find a source.
I looked on ArcadeCup, but the strips are out of stock. There are other tabs/wedges, but I'm not sure if those will accomplish the same task as the strips.
