Some progress tonight. I improved the convergence and the red is better aligned. See the pic for the improvement. Green seems a little off in these pics but I'm learning that these old monitors can only really go so far. I can improve one part of the screen and worsen another area. So, compromise seems to be the key. The green looks fine with my eye so I'm done with convergence.
Tester007 said he had smearing black but I attached a blue background pic to show that isn't always true. VR201 Black Level Control (hard to get to because it's inside between the two daughter boards) solved that!
Red is still a problem. I can't use either the Red Drive VR401 or Red Cut Off VR403 effectively. They both have to be almost entirely minimized so I don't get a red bleed. See the last two pics ... I turned up VR 403 less than half way and I get that smear. My gorf guy appears pink sometimes too because I've got red turned down so far.
Any thoughts on my red adjustment issue?
As a weird note, the reds seem to differ at each level. First level doesn't look bad, second level looks pink, etc. It almost seems like the game is programmed with different colors on the levels.
