Control panel wanted
Ghostkiller
Conyers, Georgia
Looking for a control panel that will work on an old data east cab with a 19 inch monitor in it. If you need pics of this to know what kind let me know but the guy before decided to gut teh inside of the cp and mount plexi in there to mount the buttons and joysticks on and its pretty bad. Just wanna get somethign I can work with and put a decent overlay on it. All I know is its a data east cab, kind of looks like it couldve been a cherry master machine with the square buttons hence why he chopped the cp who knows. Its just a 2 button 2 player cp wrap around and instead of clips it has 2 wing nut bolts that screw into the inside to secure it. If anyone has anything like this or something I could use let me know, I need one bad.
This cab had a puzzle bobble neo 1 slot board in it, looks like it had before that a gaplus judging by the burnin but with a tinted glass ( which Ive yet to locate and need help with as well) it shouldnt be to noticeable. Cab is a bit beat up but I think after a little putty and sanding and somie rough textured paint it will look nice with a good marquee, bezel and cp overlay.
Whoever did this put more time into this than I could imagine. They sandwiched some vinyl in between the thick plexi and the metal hacked cp and used the plex as the support for the joystick and buttons. It honestly just looked like a bad plexi job when I got it but I guestions the almost 1/4 inch thick plexi overlay protection. lol Kind of wish this was a dedicated something for all this effort. sigh I put it on the buffer wheel to remove the vinyl and get a beter look at what I was workin with. Was gonna cut some metal and weld it inside and grind it back down but just seems like way to much work for this.
22 3/8" is the length I need. If its a bit longer thats not an issue I can cut it down but would prefer a direct fit. Also Would like one with a 4 way joystick centered on it, not particular about the buttons but a galaga style layout with 2 buttons instead of just one would rock. Let me know what you have.
Bump, still lookin for one. has to be 22 3/8 in length or longer so I can cut it to fit and has to have a single centered joystick layout preferably with 2 buttons on each side but not a big deal, I can drill those.
Not sue if you are still looking a panel or not.
I have this, not exact but might work.
23 3/4 long by 9 inghes high from the hinge to the top edge.
this is from an older data east game, karte champ I think.
$20 shipped
Eric
Cointech
Yeah, ended up getting a single joystick 2 button cp off a redemption game and cutting it to fit. Should look ok once everything is said and done but if I wouldve seen that cp I wouldve taken that instead. Looks like a almost perfect fit too. Is that a 4 way joystick with leafs I spy?
