I have a PS2 that I would like to hook up to an older TV, my console has the 3 color cables, and the TV only has inserts for 2 of the colors, the red and the white. Will it work or will I need an adapter of some sort??
Basically, it'll let you plug in the PS2 through the cable jack (I would hope the TV isn't so old it's not cable ready )
Or I think you can find some kind of adapter at radio shack that'll feed your A/V cable into an RF unit...but the one from gamestop is likely cheaper and easier.
Or, if they have a VCR, it may have the yellow (video) jack. Hook up the VCR through the cable jack, then plug the PS2 into the VCR and make sure you connect to the "input" channel on the VCR to get a signal.
