Connecting up Atari Interlocks Correctly
whitefox
Donor 5 years: 2016-2019, 2024
Hockessin, Delaware
Hooking up the wiring in Monte Carlo. I've accidentally reversed the wires to the interconnect switches in another game... blow a fuse, try again.
So to avoid blowing 100 fuses and possibly my face, I am tracing the wires on the interlocks & main power switch. The grounds trace from the rear interlock to the coin door interlock just fine, so I was able to place the same black wire on the bottom.
Problem with the white wires. Not getting any continuity on these even with having the interlocks pulled out to the ON position as well as the main power switch.
So. How do I know I have the two white wires align correctly with the black ones?
