Connecting board and monitor in different cabinets
Vraz
Minnesota
Is there any problem connecting my Defender (in its own cabinet running from a Williams PS) to the G07 in my Pole Position cabinet (being powered via the isolation transformer in my Atari PS)? I need to test the video out of the Defender board and since the G07 accepts positive hsync/vsync, that seemed the quickest way. However, was not sure if having the Defender board set running from a different power supply than the isolation G07 made a difference. Seems like it should be fine, but would appreciate confirmation before just trying it.
Thanks!
I had to do the same thing in reverse... had to connect my PolePosition boards to the monitor in my CrazyKong (easiest to move closer to PP)... minus driving with my head tilted... worked just fine. :)
