Fixed.. THANKS
No, the Karate Champ video sync signal is CGA and will not display properly on a VGA monitor.
The Matsushitsa should work, it is a CGA monitor.
I really need to see the monitor chassis (circuit boards). I have never seen a Matsushitsa with a dedicated power cord. I have also never seen a monitor with the dedicated two prong power cord that was not supposed to be operated on 100vac instead of the US standard 120vac. Plugging this monitor into the wrong power source can damage the monitor.
Can you get some close up pictures of the monitor circuit boards? I think you have a Japanese monitor that was used extensively in Sega cocktail cabinets instead of a Matsushitsa.
Here's a list of computer monitors that can be used:
http://www.ionpool.net/arcade/tech/monitor_test_bench.pdf
