Complete amplifone setup
tester007
Calgary, Alberta, Canada
Was going to build a separate ZVG, but I think I will just throw it in my existing Gravitar. So I am selling the following:
- Amplifone CRT plus rings/yoke/converged. This was out of my Star Wars. I bought the game with a 6100 in it, but the seller still had the amp sitting on a shelf non-working so I bought that as well. I put in an NOS amp crt in my SW, so this sat for another project after I got it all working. Since it was sitting face-down on a shelf, the glass did unfortunately get scratched. The second pic shows this, but because the flash casts a shadow from the scratches onto the crt face, looks worse than it is by about double. I do not believe under the tinted glass Atari used that this would even be visible. The screen burn also due to flash looks a bit worse than it really is. There is about a 1 pixel pinhole in the center. Comes with dag wire and I can probably find a degauss coil around.
- Amp mounting brackets.
- blue amp deflection board. Re-capped, and bottle cap transistors replaced.
- High voltage unit. This has been re-capped, has a new flyback installed, new BU406d.
700$ can$ plus actual ship.
New pictures added.
- amp crt cleaned
- amp now comes with only blue deflection
- crt and deflection/hv fired up. CRT needs degauss as it does not have a degauss coil on it.
CRT was just gone over with a rejuvenator as well so colors are bright.
