Compact flash kit for California speed
kjeffery
Walcott, Iowa
Is there a compact flash kit avaible for California Speed. I think the one im about to get is having hd problems. About 20 mins into the game the sound will will mess up. Kinda like a cd skipping
Is it just audio? No frame skips or reboots?
Its been ahwile sicne i played it , the game used to be mine and now im getting it back, the sound will just act crazy and i cant advice to the next level or finish the race. I might get it next weekend and ill take a video and let you see it the compact flash kit will fix it. I know when I reboot it plays fine again for awhile
Could be the beginning of a failing hard drive. Are your fans running? Want to make sure its not over heating. Check the voltage as well. Usually if the voltage is low it will just reboot and not give audio issues. Check these first then go to service menu and run diagnostics on the hard drive. Takes a long time but will check for errors.
