Commonly found capacitor values
Arm123
Toronto, Ontario
I once came across a post by the one and only Ken Layton, where he posted a list of the most commonly found cap values when repairing / recapping monitors.
I'm about to go stock up on caps and tried to find his post / list, but cant.
I tried to PM him with no response...
Anyone else know of the list im referring to ?
Here is my list for shopping...
1uf 50v
1uf 250v
2.2uf 50v
3.3uf 160v
4.7uf 50v
4.7uf 250v
10uf 50v
10uf 250v
20uf 100v
22uf 25v
22uf 250v
33uf 25v
47uf 25v
47uf 250v
100uf 25v
100uf 160v
220uf 35v
330uf 50v
470uf 25v
1000uf 50v
2200uf 25v
There are a few errors on that chart.
I made up my own if anyone wants it. It contains the most common chassis' used - G07, K4600, K4900, K7000, 20EZ, & K6100...
BTW - I would've attached it here if I could've but the file is slightly too big to be an attachment.
This means that if you contact me for the list I made, you need to include an e-mail address. I've already had two PMs asking me to send it to them, but no e-mail info...
Aha! I found my list over at BYOAC forums:
http://forum.arcadecontrols.com/index.php?topic=80699.0
I think that's the one you were looking for.
It is suggested, but not required, to order 105 degree temperature rating capacitors instead of the more common 85 degree ones. This is because of the enclosed nature of where the monitors are and the heat buildup. Of course in a home use environment, the 85 degree versions will be fine.
