Common problems/solutions for a sticky joystick?
BandontheRun
Donor 2016
Connecticut
I've got a Jamma cabinet hooked up to an ArcadeSD. The joystick sometimes won't register correctly when going to the right. I am inclined to just reseat the connectors or maybe clean them with steel wool.
Is this a good idea or might anyone have a better suggestion?
Thanks!
Don't use steel wool. I dont know where the connectors are, but you probably don't want small metal fibers in most areas of a cabinet.
What type of joystick is it? Micro switch = replace the bad switch. Leaf = clean with a business card/adjust. The problem could also be wiring or connectors.
It's a microswitch. I am going to reseat the connectors before replacing anything. Thanks for the advice!
the switch is worn out. you will need to replace it.
get Cherry switches from Paradise Arcade.
