Common Failure points for the Sanyo 20EZV and Sharp XM-2001N?
TheDrewster
Donor 2012
Reno, Nevada
I am about to embark on a new project, which is rebuilding 7 of these monitors. 2 Sanyo's and 5 Sharps. I would rather buy the parts I need in bulk (like cap kits, audio transistors, flybacks, etc.) but what are some other commonly replaced parts on these monitors?
Additionally, can these monitors be used in 100v Sega cabinets as well? I would like to use my Champion Baseball setup to test these monitors rather than my restored DK or Punch Out.
if the transistors are working or test good there is no reason to change them.
i have all the caps for theses in stock if you want total cap kits including the 2 filter caps on the xm's.
they will cost more but the caps are all HQ.
i do not have the flyback's, transistors for the audio or vertical or the B+ pots.
a good re-flow is recommended as with all chassis.
as long as your Sega games are standard res then they should work fine i would think.
Peace
Buffett
