boganvilla
I'm making a JAMMA test rig and connecting it up to a 1084S monitor.
I was going to use the 8 pin DIN TTL connector on the monitor and had a question around the sync.
This connector has V sync and H sync on pins 7 & 8 respectively. Given that the PCB's I have only have 1 sync connection (composite) which sync input on the monitor do I use?
H sync or V sync?
H sync or V sync?
