Commando PCB won't coin up.
hmm I'd recommend getting one of Souzilla's Commando HSS kits... adds a freeplay option so that would take care of the coin up issue ;)
Tom
Double check the wiring... if you have a logic probe, put it on the pin where the signal comes into the board. If the light changes when you coin it up then you have a board problem.
