Well, one arm for some reason is stronger than the other, LOL.....But that is a different topic......
Honestly, It was probably closer to 90 minutes than 2 hours, but I don't remember exactly. Mylar is pretty soft stuff. I used a hand block sander, worked thoroughly with the 800 to really get it roughed up and cleaned good, and then took 1000 to it to remove the deeper scratches, and then the 1500 to make it completely smooth.
Working in straight lines as opposed to orbital (I personally believe) is the key to the whole thing when using sandpaper and polish.
As far as the DMD cover, it actually took longer and I had to use an orbital buffer, as the plastic is much harder than mylar....
Some pics are attached just for reference.... It is pretty easy to see where the "stealth Coat" is, and where the mylar is.....
I always was a fan of the location of the up post between the flippers on this one
