Ok, I was at my uncle's in Louisville last week. The machine was working great, all sounds were fine and dunk the dummy worked as it should. But there was battery corrosion on the board behind the glass. So I had to unsolder the battery connector, clean it up, reinstall and add new batteries.
After I put it back together, dunk the dummy will fall when you hit it with a ball, but will not rise again until the game is reset after a new ball comes into play. And he no longer taunts or makes a noise
. It still scores fine when the target is hit. It will also no longer save the high score after it is powered off. It did before I messed with the battery.
Did I mess something up? All settings are at factory defaults. And he makes his taunting sounds when I hit the sound test button and when it's doing it's demo thing. So I know the sounds are there.
Batteries were heald in by duct tape, hence the white residue.
No visible corrosion in the traces luckily. Hope I caught it in time.
