Combining WG K5500 Chassis with 25k7193 tube
dieseldogpi
Selden, New York
I have a working 25" K5500 standard res monitor. The glass has a bunch of chips and scratches in it from the previous owner. I found a tube and yoke from a 25K7193, would be able to be swapped? Both std. res.. Both Wells Gardner. I have never done a tube swap before, done cap kits and what not, but nothing of this magnitude. Thanks for the info.
I have both monitors myself, but have never looked at them as far as tube compatability. As long as the number of pins and deflection angle is the same, I'd think it would work, but you'll most likely have to swap the yoke...
