Coin switch wiring in my DK
Shavenyak
Donor 2023
Sarasota, Florida
I've got something weird going on in my machine. It's been this way for years but I'd like to fix it. The coin switches are wired with an orange wire and a brown wire. Either side will work when the other side isn't hooked up. If I hook both switches up, neither work. Suggestions?
This happened to mine as well.
Make sure the coin door wiring is connected correctly and power down the game.
Disconnecting the coin door wiring molex directly from the main PCB.
Reconnect it and then power the game on.
That should fix the problem.
Let me know if that works.
