Superully
Coin Reject Lever for old Atari coin doors (e.g. Gran Trak 10)
hi guys!
in order to have the coin door of my gran trak 10 powercoated, i need to remove those coin reject levers:
however, one of them had obviously been removed before, because it is not fixed with the usual headless screw / set screw / grub screw (whatever the correct term for it is), but someone has nailed some kind of bolt into it. i've carefully tried drilling it out - without success.
before i try harder, i'd like to know whether there's another way to get the lever off or whether i would find replacements in case it gets destroyed ...
i'd also take an entire assembly if someone has one lying around. here it is from the back of the coin door. as you can see, i can't simply pull the metal piece out with the coin reject lever still attached (which would be fine) because that metal tube is blocking any further movement! damn!!!
hi guys!
