andrew96
Hi
I have replaced the cashflow 126 with a cashflow CF9524e
If I inhibit tokens on the CF9524e the 20p coins work on the coins in, if tokens are enabled 20p coins will only work down the token slot, how do i get 20p coins to work down the coin slot while tokens work down the token slot! i cannot see how in the instructions.
I would like it to be the same as a cashflow 126 which the manual says it is compatable!
anyone had this issue?
thanks
Andrew
thanks
Andrew
