I'm trying to wire the coin door lamps up for my Raiden Cabinet. I got the microswitches working correctly, and along with the grounds and coin start wires there was another +5v wire all coming from the board. Can I use this to power my coin lamps or should I run them straight from the power supply. I put a meter on it and it was only +4.83v. I hooked it up to the lamp and it was pretty dim.
Another question is were can I order more of these lamp holders? I tried to order some from suzo-happ and the ones the sent me are the ones in the third picture. Which is way different then the one I need which is picture 1 and 2.
