Coin Door Hinge Pin?
troxel
Donor 7 years: 2015-2021
Lincoln, Nebraska
Have a Bally coin door (1979) and is missing the pin that hold the hinges together. Is there any special to replace it with? I would imagine that home depot would have something, but anyone know what size it is?
Thanks.
Did you ever find the hinge (piano) wire? If you need, I can measure one for you. I just started a thread looking for NOS hinges so we will see what that brings.
Two thoughts if you didnt find the wire at home depot. An old style metal coat hanger. Or, I know that Aircraft Spruce sells piano wire for hinges. you can do a google to find them.
I just went to the hardware store and bought a metal rod and bended the end. I can get the thickness if you want. Worked well for what I needed.
