Level42
I've bought a couple of Coin Comparitors a while ago and now want to install them.
After some Googling I found a document with all info here:
http://www.coinmech.com/images_products/images_supporting/455.pdf
The model I've got is the CC-40E.
The CC-40 has the following pin-out according to this doc:
1- Tilt
2- Inhibit or 10mA source
3- Credit
4- +12VDC or 24VAC/DC
5- +12VDC or 24VAC/DC
6- Ground
Now I want to hook it up with the AC that's already available in the coin door. So should I connect the wires to 4 and 5 or to 5 and 6 ? (or 4 and 6) ?
I measured ohms between 4 and 5 and got about 100 Ohms resistance so they are not electrically the same point.
1- Tilt
3- Credit
6- Ground
