Coil Confusion
jphillip5
Iowa
I need to replace four coils in my Bally Power Play machine. The coil numbers listed in the manual are as follows:
CN-31-2000 (Chime)
NO-26-1900 (Drop Target Bank)
AN-26-1200 (Pop Bumper)
AO-25-500/34-4500 (Upper Left Flipper)
I believe I've found a replacement for AN-26-1200 with AO-26-1200, however it doesn't include a diode. Is the diode necessary?
I also found a cross reference table that suggests that AQ-25-500/34-5050 is the proper replacement for the flipper coil. Just want to double check that this is correct.
Thanks in advance
