Azurden Well-known member Donor 4 years: 2013-2016 VAPS Joined Aug 6, 2013 Messages 2,663 Reaction score 64 Location Fairview, Pennsylvania Nov 6, 2017 #1 Any of you guys used raspberry pi to build a cocktail table? The control blocks I have seen seem to be only for one controller and associated buttons. Also was not sure if when emulated in pi if it will do the screen rotation for player 2?
knohbody Active member Joined Mar 16, 2012 Messages 432 Reaction score 25 Location Texas Nov 6, 2017 #2 If the game settings support cocktail mode, then it should. Are you building from scratch or converting an existing cocktail? If converting, check out pijamma, it interfaces through the jamma harness.
OP OP Azurden Well-known member Donor 4 years: 2013-2016 VAPS Joined Aug 6, 2013 Messages 2,663 Reaction score 64 Location Fairview, Pennsylvania Nov 7, 2017 #3 Thanks will check that out. It is a conversion... The table was gutted years ago. Needs everything.
