natey_boy
BEWARE. Known scammer. Will take your money and se
So now that my hand is healed up and im able to fully work on things again I decided last week to start a cocktail multi game cabinet build (60-1) So after deciding not to use the cocktail my trivia wars was in I figured I would just build a new one. Black Melame is hard to come by here as you need to order minimum of 8 sheets so I used plywood. I will post a picture later of the cabinet. It turned out great and once I get the t-molding installed its going to look even better! Then I shall install the glass topper and monitor and possibly even a wiring harness and power supply (if I have time) and then I will just need to source a coin door and mechs. Eventually I will need to replace the monitor as its a g07 that has some burn but its the only spare I have laying around that wasnt broken lol. so yeah will post pics later.
So I need an opinion, was thinking about placing some sort of artwork around the coin door and wanted some opinions first! Any ideas as to what will look good?
