Cocktail assembly
kpkube
Valencia, California
Getting ready to assemble a new cocktail table (CNC by OU Flight) http://forums.arcade-museum.com/showthread.php?t=192763
Need to paint the top black. inside of control panel sides black, staining outside.
What is the best paint to use.
staining the rest. any suggestions?
attachment.php
On areas that small and not really seen much you should have no problem just using regular spray paint. Just don't put it on in one thick coat, follow the instructions on the can or practice a little on scrap parts and you should be fine.
As for staining just go for it and if you can after wards put some clear on top.
