Hi,
I'm working on getting my C&D board working in my multi-williams cabinet (swapping jamma connections to play). A strange thing I've found is that move/fire is swapped. The multi williams (this is a defender cab) CP works great with ArcadeSD, JROK MWMS, and Arpicade. So I expected that the Jamma converter for the C&D would work correctly and use the joysticks in the same place. Is there a switch/option that would change this? I can't find anything.
I'd hate to have to build another adapter just to swap the joysticks. Swapping the connections to the sticks themselves is not an option as I want to use a Jamma switcher in this cabinet.
-Jeff
-Jeff
