Steve W
I took the old battery off my Cliff Hanger machine and when I did it would still boot up but take a few tries before the final beep would cycle. So I took the PCB out and a tech showed me how to put a new battery on. He soldered the bottom of where it once was put some wires there and attached a 3.6v battery which I taped to the bottom of the cab.
I put everything back and got a loud hum and a grey screen. PCB LED is lit up but does not beep at all now.
I then took the battery back off and tried again but get the same thing. I've attached some pics, maybe I put the PCB's back in wrong or something? I am a novice with this stuff so if you see something I put back incorrectly in terms of the PCB's please post.
Failing that if you can recommend someone you would trust with your life essentially to look at the board that would also be good. Everything else seems to still work fine so I'm sure there's some issue with the board now. Thanks.
