Cleopatra problem, could use some suggestions..
if the slam and tilt are as they should be
i'd verify you have +5V on the CPU
sounds like its lobotomized from the lack of proper +5 voltage
see what the value is on the PCB board
have you done the ground MODS ?
Yes the ground mods have been done.
I've also posted over on RGP and and the direction is leaning to Z29 needing replacement. (http://rgparchive.com/rgpforum/showthread.php?t=334280&page=1)
Strange the coincidence of a bad chip after the reassembly but it appears to be a common problem. I'm just thankful for the help and direction, don't think I would be able to solve this without it.
VB,
