Mister Timmy
Hi all....
I came into an original Contra / Konami cab recently and nothing on the inside was bolted down / secured with the exception of the
PCB board which was properly mounted to the side wall .....
So, I screwed / secured the isolation transformer away from everything else to the bottom floor so it wouldn't move .....
There are two (2) "cup like" fuse holders which appear to have holes in them to screw them down someplace, but they are loose ....
The power supply itself is just sitting loose inside the cab ......
What's the best way to secure the cup like fuse holders? Whats the best way to secure the power supply? Power supply doesn't appear to have
any mounting brackets attached to it.
thoughts?
thoughts?
