Cleaning a 49-way Optical Joystick?
RussMyers
Harrisburg, Pennsylvania
OK, as part of restoring my Sinistar's control panel, I have disassembled and removed the 49-way Optical Joystick?
I've given all the parts a thorough cleaning, but I have a question about re-assembly.
The 3-part metal collar and bearing assy. that the joystick shaft slides into had some dark grease that I scrubbed off after disassembly during cleaning.
What grease (if any) should I re-apply to this area, where, and how much?
Also, does anyone have a PDF of the manual for this 49-way Optical Joystick?
Thanks,
RM
USE Dielectric Grease , PUT ON AS MUCH AS YOU TOOK OFF, THAT SHOULD WORK JUST FINE. . .
