cleaner for artwork side of a flaking glass bezel?
TheShanMan
Donor 2011, 2024
Hillsboro, Oregon
Just picked up a Rally X and the bezel is pretty good but has some flaking. It's quite dirty on the artwork side though so I'd like to know what cleaner/chemical. Soapy water? Naptha? Goo Gone? ;)
I will of course stay away from the spots that are flaking but would like to clean up as much of it as possible.
As long as it doesnt have ammonia in it (dont use Windex) and you be careful around the flaking, you should be fine.
soap and water but keep in mind if the area you are trying to clean is flaking you will likely cause more damage cleaning it.
Soap and water is what I was thinking too. And I'm definitely staying away from the flaking areas! Thanks guys!
