rmackie6661
well I have a Ton of stuff to get rid of MMAO please consider shipping costs from 55016
- Lot of about 40 buttons and nuts.
- x5 xxxx-1 CGA adapters for the VGA input on the Baby star PCB's
- Box of Button label tags and Button Spacers (1.5lbs)
- Wells Gardner K7500 and 7000 metal Monitor frames.
- x4 110v Cooling fans like the ones on pole position
- Merit touchscreen Coin door setup (slide in kind like on most MAXX and Xl systems)
- x4 pole position Steering sensor PCB's and one harness
- NOS woodgrain Atari Shifter Knob Part number 047797-01 Set screw type
- Pacman / Ms pac PCB repair kit (Caps)
- Sega 16 to jamma Addapter
- x11 positive Sync Wells gardner 4600 RGB/ sync cards
- x2 Wells gardner P371 cards
- x 5 coin counters
- x1 Gottlieb Power switch cover like on Q-bert inside
- Nintendo Wide body upper and lower marquee brackets
- Vanguard Monitor Bracket
- Hang On Upper Marquee bracket
- Nintendo Dual VS cab Upper and lower Marquee brackets (these are for the Side by side cabs)
- Pengo Lower Marquee bracket
- Centui Pheonix Marquee brackets
- Midway monitor Shround mounting brakcets (the wide metal pieces that the bexel attaches to x one set)
- Nintendo Cocktail parts ( Hinge and the keeper)
- Bally Sente Speaker Grill X2
- Rolling Thunder Speaker Grill
- Asteriods Speaker Grill
- Vanguard Speaker grill
- Rolling thunder bottom vent cover grill x2
- Q-bert Speaker grill
- Hang On Grill ( vent )
- Nintendo Wide body speaker grills x 2
- Scramble Speaker Grill
- Sterns Style Speaker grill X5
- wells K7000, G07, Kageki manuals and Rampage and DKJr dip charts
- Nintendo Monitor brakets x2 sets of sides and top and one set or just the sides
- Defender Metal PCB mounting piece
- Lot of trackballs x3 3" and x4 2.25" some good some for parts.
- x15 Iso transformers ( heavy) all tested good
- Lot of 43 Misc Joysticks and parts (32 pounds worth)
- 120 and 80GB hard drives. No idea what's on them
- Mountable Ashtray
- x4 NOS side mount drink holders hold x2 drinks each
- U5000 yoke
- trivia master PCB and wiring harness
- Lot of about 30ish monitor bracket holders (grey strip kind)
- Taito Power supply transformer (heavy)
- Nintendo Power block out of a caberet cab. (heavy)
- Nintendo 24v power supply ( burnt R1 otherwise good)
- Sterns Berzerk Coin door, trim and harness complete minus mechs
- Tempest Monitor brackets ( for the bezel and glass)
- NSM performer 2000 wall mount Jukebox manual
Let me know not looking for much just trying to clear out some parts I'll never use.
if you need pics my email is [email protected] first come first serve I'll delete the parts as they sell. Ross...
- x 5 coin counters
- Mountable Ashtray
- U5000 yoke
