Clean, capped and fairly cheap kortek 19" monitor $125 shipped
chris25810
lake elmo, Minnesota
I'm not a huge fan these monitors but this still has a pretty good tube so i cleaned it up and capped the chassis. The flash is making the burn look alot worse than it really is and it has a nice crisp colorful picture. The frame is universal so it can be mounted either horiz. or vert. Send a pm if you're in the continental U.S. and you want it. This has the typical Kortek 6 pin video header with R G B HS and VS there's also two dip switches (HS and VS) that you can play around with to get the right sync combination.
