Clay MultiWilliams kit boots without sound randomly (low % of the time)
gwarble
Petaluma, California
my girlfriend and i have been turning it on almost daily to play bubbles, and every once in a while it has no sound... easily remedied with a reboot
the first time this happened was with some first time visitors (nutballchamp and a few other collectors) so that sucked...
its happened now two other times over the last few weeks, so not very often... and rebooting with 1p and 2p starts fixed it each time but the first (i didn't try)... this works because its clay cowgill multi-williams kit, which boots directly to bubbles... this may have something to do with it
otherwise, is this a known problem with this kit? without the menu there to trigger the sound reset line... i don't know
it otherwise functions perfectly and that sound reset line is definitely hooked up... i'll have it boot to the menu for a while to see if it ever occurs without a direct-to-bubbles boot process
thanks for any tips...
an aside, i'm slowly designing a MW panel for this bubbles, is there a hack to get bubbles to run with the robotron-fire joystick? (or 2p joystick it may be called) i know jrok's board has that option, maybe a rom hack for clay's?
- gwarble
