Claw game joystick help, please!
Guru-420
Hubertus, Wisconsin
I have a claw game I got recently, a 1993 Clean Sweep. One of the first problems is a bad joystick, mine doesn't center and one of the switches sticks. I am also having a heck of a time getting the e-clip back on. I'm thinking of swapping it out completely and getting a new one to install while I try to fix/rebuild this one. Could someone please point me in the right direction? The manual doesn't seem to list a swap-out replacement. Will this work?
http://na.suzohapp.com/amusement_products/joysticks/50-7008-000?SS=ON
Yep. That's the one I use.
Dave.
Just to close up this thread...
The replacement joystick worked great. 4 nuts removed from underneath and the entire assembly popped right out. New one was a pretty close replacement. Only issue I found was a difference in the tab sizes on microswitches. The previous version used a .250 tab size, the new one used a .187 tab size. Luckily, the hardware store next to me had 1 10pk left, so I replaced them properly the same day.
