CL: $100 Ms Pac-Man Cocktail, plays blind
john2654
Donor 3 years: 2011, 2020, 2024
Rhinelander, Wisconsin
CL: Ms Pac-Man Cocktail, plays blind
Per Craig's List ad:
"Hi, I have an 80's Ms Pac Man Cocktail Arcade game.
I've been trying to get rid of it forever. I don't know much about it, but it needs a new fuse for the video output.
It turns on, lights up, and the audio works fine. Just cant see the screen because of the burnt out fuse.
I was told you can pick them up at any electronics store or online. I just don't have the time or knowledge. It's a little dusty, I'll clean it up for you. Like I said, I'm no expert."
Hmmmm....
pac
fixed, its still worth 600-700
likey needs monitor repair or replacement, fuse wont do it
Finally got to pick up the cocktail. Added pictures on the first post. Does play blind. Missing the player 1 CPO overlay, otherwise complete. Monitor is dead. Chassis board looks toast. Did a reading on the AC plug going to the chassis and it's pumping out about 135-140V AC.
Looks like a G07 monitor. If you install a rebuild kit from Bob you have a very good chance that the monitor will be fixed.
Is 135-140V AC normal for the chassis? I thought ~120V AC was normal coming out of the isolation transformer.
go7
when the game and monitor are working the ac going to the monitor would be close to 120
right now it has no load so its a bit hi, that normal
