Cisco Heat and Big Run pinout and dipswitches?
bongoben
Wisconsin
I'm looking at the possibility of throwing a Big Run pcb set in my Cisco Heat cab. I know BR is a 4-board game while CH is 3. The main edge connector harnesses look the same as well as the RGB sends to the monitor. The only problem I'm seeing from pics of a BR PCB set is that there is a spot for power on each of the 4 boards while CH only needs power to 3 boards. Does anyone have the pinouts for these two games for me to compare to see what I might need to add to a CH harness to get BR working? I don't know if the CH manual has this info as I do not have it but the BR manual I've found online does not have pinout info in it.
Also, does anyone have the correct dipswitch settings for Cisco Heat? This is something that I assume is in the manual but since I don't have one, I don't have them. The settings I found online are not correct/complete. The CH board has 2x 8-switch and 1x 4-switch. The biggest thing I'm trying to figure out is how to turn off the demo sounds.
Thanks!
Big run
I had one of these a while back that I had to do a lot of stuff to in order to get it running. I never found a pin-out for it. I imagine some one has a manual for it by now. I just had to figure mine out.
