cinematronics wierd behavior after status light mod
wugly
Massachusetts
Was working on my cinematronics space wars because it had no video and would not run blind. I had it all fixed and working and decided to do the status light mod. game seems to work fine if I pull the 74 s00 chip out of a2. when it is inserted the led flashes on power up and goes dark like it should. my problem is that when I look at the screen my time on the game has exceeded 300 minutes and is on its way up as I am watching it. I cut the 2 traces on the top of the board going from 3 to 11 to 8 and put a jumper from3 to 6 and 8 to 12.
I followed this you tube video.
It seemed to work my only problem is the time going up. I disconnected the control panel and I still have the same problems with the time. been going over it and have not seen my error.
I am an idiot. Been up 17 hours and I missed cutting a trace. Will cut and test in the morning when I can trust myself again. Didn't cut all the traces to pin 5
