cadillacman
Ok heres where im at with this thing
I got it, its the baseball season II by cinematronics. I guess its the cinemat system??
Anyways its in a berzerk cab with a wells 4600.
WHen i got it the power was unhooked. WHen plugged in, the flyback started smoking.
I replaced the flyback and that made it power on, to a thin horizontal line.
I did some trace work on the board with the holds, now produced an image thats green mostly and will not sync.
I traded daughter cards, etc, still canot get to sync.
I backed up another game with a 4600 in it and swapped video connectors.
WHile only green and blue, the questionable monitor syncs fine with the other game.
THe other known good monitor is just like the other now, will not sync, but this one has all the colors of course.
So... i have two issues i guess...
-original monitor missing red but does sync fine with a different game.
- original pcb/wiring will not sync with any monitor.
At this point i need to make sure it is wired correctly, as the wiring in this thing is pretty bad. Does anybody have a schematic? I got a game setup manual with it but no schematic/service manual as to how the video is pinned out at the game pcb. If i can get it to sync i will fix the colors issue, if not i belive this game might end up as parts.
i think i need to see the schamatic that would most likely be in this book
http://www.ebay.com/itm/CINEMATRONI...-SERVICE-MANUAL-SCHEMATICS-1985-/150674797305
id love to get this working.
