Cinematronics Condor Power Pinouts
SteveJ
Purcellville, Virginia
I just put new breakers in my Condor power supply, and made the following chart to help me test the supply before I hooked it up to my Star Castle machine.
You can get the pinouts from the schematics in the manual, but the actual pins are a little different. The diagram shows the pin arrangement as viewed by looking at the connectors (vs. the PCBs).
The Male plugs (CCPU and Audio) are numbered right-left/bottom-top, while the Female Plug (Monitor) is numbered left-right/bottom-top. I also put actual readings from a "healthy" power supply along side the pinouts.
Anyway, picures are worth a thousand words, I thought it was worth posting for anyone who wants to check out a Cine power supply.
SJ
