Cinematronic/ Keltron Star Castle adjustment
FlashbaxArcade
Burleson, Texas
i just fixed(capkit and resoldered all wires and connector pins) a Keltron monitor on a Star Castle and can use the 4 pots on pcb to adj linear and gain but still is off from side to side(H) and i have to move color shield to make it look good!
any ideas what makes the whole image move left to right?
Sounds like you might need to adjust the 2 metal centering rings on the back of the yoke.
yeah that's what i was thinking but i've never worked on a B/W vector, and i know you really don't wanna jack with color ones if you don't have to! was kinda timid about adj that....i would guess that that is the only solution/fix?
is there a trick to adj those?
