NEW Chrome and klov
Dialsoft
Donor 10 years: 2016-2025
Wharton, New Jersey
Anyone have issues using chrome here in text boxes? I noticed a good amount of the time I need to switch browsers because you cannot type in text boxes on here.
Same problem here. Originally thought it was
my ad blocker but I white listed KLOV and it
still exists.
I just noticed if you click the quick reply icon it turns
white and allows you to use it. Not sure why it's set
up this way.
Won't keep me logged in on chrome on pc or safari on iPhone.
Can't see polls.
Various other problems.
I think it's DB problems.
I don't use Chrome or a Chromium-based browser very often. My main browser on PC is Pale Moon, which is Mozilla-based (like Firefox). The only real problem I have is a fairly intermittent one. Occasionally the quote feature will stop working correctly. It won't quote the person's text at all; just gives an empty text box. I have to copy and paste the person's text from their post and then make the quote tags manually. And when this quirk happens you can't use the preview function either. If you hit preview it will wipe out all of the text and you have to start over. If you just hit post, it will post it, but then if you hit edit the text box is empty again, so you can't edit it. Then after a while (usually hours but sometimes days) all of this goes away and everything starts working fine again. I do have long stretches where everything is fine though.
I use Chrome daily here on multiple machines, and don't have any issues.
I'd look at what other software, ad-blockers, etc, you have.
i have to agree with andrewb here. you people need to put down the crack pipe and show
some proof (with version #'s, modules installed, debug analysis of problems, etc) to make
your point. the general masses do NOT have any issues with this site. it's a basic website
using basic vBulletin (outdated) php software using simplistic mysql/mariadb for the db.
i use chrome for the past 5+ years here and to this day, i have had -0- problems with it.
I have the same issue on Android device. Cannot type in text boxes. AAAANNNDDDD.....cannot use the seasrch function due to that.....
Could be browser extensions. I rarely change/add/remove mine, but some do auto-update blocklists and could causes problems for a bit until the next change happens.
....probably just a fuse!
But seriously...I have that issue as well. But only sometimes!
I can't reliably repro it so it remains a mystery.
Jesus this isn't a murder trial we're talking about here.
