brocksampson
Not sure if this is the right section but here goes. I'm rewiring my choplifter cab with k7000 monitor with a new twisted quarter jamma harness. I made a jamma adapter and tested it on my bench no problems. I'm having problems with getting the picture to sync. I have tried all variations of sync wires. Both tied together, just -v, just -h. I have put a new end on the sync cable and new end on the ground cable still no dice. Just to verify I didn't screw up the adapter I put my test harness in and it syncs great. I traced the wires and all look to be in the correct location on the harness. My test harness only has -v sync. Attached are pics of the image with new and test harnesses as well as pinouts of each connector. I don't understand why it won't sync with the new harness. Any help would be appreciated.
